Hi guys
Need a quick advice! Can buy a pair o Beolab 5 for a very reasonable price here in Switzerland.
They are from a shop with warranty but they are MK1 – the ones with serial 1.62 and NO sync options. I’m not shure if they work perfect in my setup.
My current setup:
- Beocenter 2 with Beolab 2 /3 connected with Powerlink
- Beolink PC2 (Beoport) integrated in the Masterlink
- Mac Mini connected to the Beoport and operated with N-MUSIC and the LinkPlayer solution
My idea is to connect the Mac Mini by using the digital connections direct to the Beolab 5 and still connect the Powerlink to the Beocenter 2 (For Radio / DVD).
I control the Mac Mini with teh LinkPlayer solution.
- How can i control the Volume? Does it works trough the Beocenter 2?
- Is it a problem when the Beolab 5 are the “old” MK1 ones without Pincode and without option to sync the volume between the two Beolabs?
Thanks for the helpful answers
