Latest post 02-07-2012 7:24 AM by riis. 10 replies.
Page 1 of 1 (11 items)
  • 01-30-2012 4:09 PM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    Beocenter 2300
    I'm thinking of buying a Beocenter 2300 to replace my CD 50. What common faults do I have to look for. How is it compared to my Beomaster 5500/CD 50. The one I might buy comes with a MCL2P amplifier.
    /riis
  • 01-30-2012 5:27 PM In reply to
    Re: Beocenter 2300
    I would check the doors open smoothly and evenly and close evenly and smoothly too. See it plugged in and working. Check it plays CDs of course and doesnt make any funny noises.
  • 01-31-2012 12:40 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: Beocenter 2300
    scotchbonnet:
    The cd sometimes just spins without playing. Is this a matter of cleaning or is the laser faulty? Has the laser on Beocenter 2300 got a bad reputation?
  • 01-31-2012 2:02 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: Beocenter 2300
    riis:
    scotchbonnet:
    Doesn't anybody know if the laser might be faulty. Can I buy a working cd-unit somewhere? It's impossible to buy a cd-unit in Denmark unless you are a B&O licensed repairman.
    /riis
  • 01-31-2012 2:06 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: Beocenter 2300
    riis:
    scotchbonnet:
    riis:
    scotchbonnet:
    Doesn't anybody know if the laser might be faulty? Can I buy a working cd-unit somewhere? It's impossible to buy a cd-unit i Denmark unless you are a licenced B&O repairman.
  • 01-31-2012 2:08 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: Beocenter 2300
    Sorry.................
  • 01-31-2012 2:22 PM In reply to
    Re: Beocenter 2300
    The Beocenter 2300 CD mechanism is, as far as I know, out of production.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-31-2012 3:19 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: Beocenter 2300
    Søren Hammer:
    Don't you think it's possible to get a refurbished one? But as mentioned before, I'm not sure the cd is faulty. The seller tells that the cd sometimes just spins around.
    //riis
  • 02-01-2012 3:54 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Beocenter 2300
    Cd prob - is it from cold or when the unit has been in operation for some time?
    If when cold could be the lubricant(?) is a little hard but softens when warmed up! - ie on the sled
    Does it happen with the same disc or different ones - if cd specific could be the disc!
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 02-01-2012 5:32 AM In reply to
    Re: Beocenter 2300
  • 02-07-2012 7:24 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: Beocenter 2300
    I bought the Beocenter 2300 after all. The laser wasn't faulty. All it needed was a good cleaningBig Smile
    /riis
