This what I did with my pentas - removed the amps, then re-threaded the amp cable out of one of the horizontal gaps at the rear, and then some speaker wires from the speaker out between amp and speaker, you could of course route this the same way as the amp wires. I then re-attached the amp module and terminated the wires with the typical 2 pin dins used by B&O i.e. female on amp side and male on speaker side. This allows me to quickly dissconnect the penta amps and connect another amp straight to the speakers without going through the amp. Works well :) and sounds much better than the 'offical' way!
Of course, as Mika says if you are not going to use the penta amp at all you might as well remove the amp and displays and sell them, this has been discussed recently!
