Setup: Beocenter 2 MK I on Beovision 7 MK IV with Beolink 1000 remote (previously Beo 5)
When starting the cd there is no sound. If I shift to DVD on the remote there will be sound from the CD. But also TV-position and the screen is "alive" with a slight light.
When starting a dvd there is sound and picture. As expected
When starting radio there is sound. As expected
This is both via thhe relote and drirectly on the Beocenter 2.
The Beocenter 2 is set up as AV1 , DVD, Beocenter 2 MK I.
I have tried to switch to AV3. Same reusult.
I think the option is 2
Presumably a ML problem; I presume the BC2 is ML connected? It should!
if you don't have any speakers connected to the BC2 the option should be option 0
Yes, it is ML connected
The display on both TV and Beocenter is correct (stating CD). It is only the sound that is missing!
