Latest post 01-28-2012 3:34 PM by moxxey. 8 replies.
Page 1 of 1 (9 items)
  • 01-27-2012 11:05 AM
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Sky record button combo from a Beo4?
    Ok, since buying my BV10-46, it appears to have a new Sky remote PUC which is different from the one I've been used for for the last 5 years!
    For example, using my BV7 and Beo4, to record a Sky programme, you simply pressed GO + red button. Now, that sets the timer. So, how on earth do you record a Sky programme using your Beo4?
  • 01-27-2012 2:50 PM In reply to
    Re: Sky record button combo from a Beo4?
    Go and 8?
    If you press menu, does it not overlay all the available options down the left o the screen? if you are ona link room, press menu in front of the main tv to see which option you should be using
  • 01-27-2012 2:57 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    rednik:
    Go and 8?
    Thanks, that's the one! Should have looked it up, but thought it was quicker to ask the question.
  • 01-27-2012 5:05 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Go red also
    And if you press menu once you will get the conversion on the side menu that appears
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 01-27-2012 5:25 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Seanie_230:
    Go red also
    As I said, it doesn't work.
  • 01-27-2012 6:39 PM In reply to
    Kind advice anyway Seanie.  Moxxey that sounded dam rude!
  • 01-28-2012 9:05 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Not rude Tod, I was (and am) annoyingly quite ill, so only managed a few words. Wasn't supposed to be rude. But forums do that. People interpret written words very differently than body action.
    Anyway, thanks for the help guys!
  • 01-28-2012 12:27 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hello
    Dont worry I did nt read it in a rude way.
    Get well soon...
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 01-28-2012 3:34 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Seanie_230:
    Hello
    Get well soon...
    Thanks Seanie. Lot better tonight - I think it was just one of those end-of-week run down things you can get after a hard week!
