Latest post 01-27-2012 6:42 PM by MartinW. 5 replies.
Page 1 of 1 (6 items)
  • 01-26-2012 4:25 PM
    Beo6 Configuration tool.
    Hi.
    I have a problem with programming my Beo6 remote after update to newest SW
    I have the configuration tool version 4.11, and after a SW update on my Beo6 (running V2.11a now) remote I’m not able to write the new setup to my remote.
    I have no problem reading my remote, but no way of writing the new setup.
    Can we find a newer Configuration Tool SW version. (The store is running 5,17)
  • 01-26-2012 6:03 PM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Re: Beo6 Configuration tool.
    I think I had a similar problem.  Running XP on my service computer.  After saving the configuration, shutting the tool down completely and restarting, I was able to get profiles to load.  Hope this helps.
  • 01-27-2012 11:22 AM In reply to
    No this is not helping.
    I'm running Wndows7.
    I can do all programming. After I have chosen "Download Configuration" the program is starting to compile the program.
    But the Bytes is not counting up at all, all the numbers of bites is not showing at all.
    Has anybody tried to change the setup on a Beo6 running version 2.11a with the CT 4.11 ??
    Is it possible to find a new SW version for the CT??
    Steen Clausen
  • 01-27-2012 4:47 PM In reply to
    Which version of Windows 7? 32 or 64 bit?
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 01-27-2012 4:59 PM In reply to
    Sorry.
    It is 32 bit version.
    And I had no problems before the SW update of my Beo6
    Steen Clausen
  • 01-27-2012 6:42 PM In reply to
    Hmmm. I have the 64 bit Windows 7, which won't work with Beo6 at all.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
