Latest post 01-25-2012 10:57 AM by tournedos. 4 replies.
Page 1 of 1 (5 items)
  • 01-25-2012 8:26 AM
    Beolab 6000 - problem.
    Hey guys
    There is a pair of beolab 6000s for sale online near me (yahoo auction). They are being sold as broken. I have contacted the guy and asked for more info. They are working. They power up and play fine at low volumes but when the volume is increased there is a 'detoriation' in sound quality. He says it is like an electric grating noise.
    Does anybody have any ideas what this issue is? I may just pass on them but I am skint at the moment (uni is expensive here). I don't mind paying for repairs but don't want to get stuck with a blackhole for money! He can't check the speakers themselves as he doesn't know how (?).
    Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
  • 01-25-2012 8:44 AM In reply to
    Re: Beolab 6000 - problem.
    Torn woofers is my bet.
    -mika
  • 01-25-2012 8:56 AM In reply to
    Yeah, that was my first bet. Any idea of the cost of a repair either buy myself or from B&O?
  • 01-25-2012 10:05 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    B&O only cahrges $120 for the set of 4 woofers. Easiest thing in the world to fix. The hardest part? - getting the fret off. Laughing
    At that price its not even worth your trouble to refoam.
    Smile
    Evan
  • 01-25-2012 10:57 AM In reply to
    Although, after replacement, you need a signal generator and an oscilloscope / AC voltmeter to calibrate the driver levels. But if the speakers are for your own use and you don't care about the frequency response possibly being some dB off, well.. you don't care and just forget about it.
    There's also the possibility of the speakers having some other faults. But if both of them are the same, it's probably this usual case of cone surrounds having split.
    -mika
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
