Did some more work on my B&O3000 today and it has been quite fruitful, although the R ch is still dead.
I have a basic signal injector which I used systematically to test each transistor stage. A very effective piece of equipment that saves a lot of time checking the individual components, both passive and active. About 4 or 5 transistors were replaced as well as a few resistors and the diodes. I applied the signal to the base of each transistor starting from the output stage. Some curious results occured:
1) Base of TR50 (lower 3055) did not transmit the signal. Replaced it and was now OK. However, a diode test of the old transistor shows it is still OK (as reported yesterday). Strange!!!
2) Injecting the same signal to the same transistor on each channel produces different noise intensity.
For example, TR40-42 signal is louder on the left (good) channel than on the right.
3) TR37-38 (used BC182B) proved the most difficult. Signal is heard faintly on the L channel, nothing on the R ch. The end result is that there is no output from the R ch with FM switched on.
Can someone please explain the problem with point 3)??? What should be my next step???
Many thanks in advance. Regards,
f_b
