Latest post 01-25-2012 3:04 PM by rkammer. 5 replies.
Page 1 of 1 (6 items)
  • 01-24-2012 1:04 AM
    Shipping a Beogram 5500 safely
    I am currently selling and will soon be shipping a Beogram 5500 to its new owner.  It will be shipped within the USA by FedEx.  I have located the tansport screws on the bottom and they seem to lock the platter down.  However, do I still need to remove the platter and platter base for shipping?  Or, can I just put packing material between the lid and platter to hold it down?  Any other measures to consider?
    I will also be shipping a Beocenter 9000 and have installed the two tansport screws on the bottom for the CD drive.  Any other measure on this one as well?  I will be double boxing both units with professional packing materials.  Thanks for your guidence.
  • 01-24-2012 1:45 AM In reply to
    Re: Shipping a Beogram 5500 safely
    The Beogram 5500 platter would have to be taken off, and some protection against arm rolling should be inserted at the arm slot in the back. Ship the stylus seperately in a safe box.
    You should also take some precautions when shipping the Beocenter 9000. The lower glass panel is known to loosen under transit, as it's just attached with double-sided tape. It it loosens, it will scratch the surface and self-destruct in small fragments of glass. See this video as a scenario of the damage done when shipping one of these wrong: http://www.youtube.com/watch?v=e3KxGmcpRZo
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-24-2012 9:20 AM In reply to
    Søren Hammer:
    Ouch, that hurts to look at it.  So, if I float the unit inside a double box with foam around the glass panel that should do it best I can, right?  Thanks for the advise.
  • 01-24-2012 11:24 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Seen this?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-24-2012 10:39 PM In reply to
    kallasr:
    Seen this?
    Ralf
    Good advice to follow.  Many thanks.
  • 01-25-2012 3:04 PM In reply to
    Søren Hammer:
    Just want to clarify about taking the platter off.  There is the top platter, then there is a black spacer beneath it and then, the main platter base that has the gear attached and the belt around it.  Should these come off for shipment also and belt removed as well?  In addition when the belt is taken off the drive spindle it is not tight againist the platter base but rather it falls off.  Is this correct or is this an indication of a worn belt.  (the turntable does play normally and all functions work properly).
    Thanks again for your guidance.  I want the new owner to receive this turntable in good shape.
