Latest post 01-23-2012 3:08 PM by Seanie_230. 2 replies.
Page 1 of 1 (3 items)
  • 01-23-2012 10:44 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    CAT 7 Pin Diagram
    Hello All
    I am about to put in some CAT7 cable under my floor before installing the covering.
    Currently there is masterlink and this is just conencted two a junction box at each end but as this will be under the floor i would like to put in CAT si if need be I can use it for something new and wonderful in the future.
    What is the pin configuration for this cable so i can use some for ML in the mean time.
    thanks
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 01-23-2012 1:54 PM In reply to
    • benjnz
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Auckland NZ
    • Posts 392
    • Gold Member
    Re: CAT 7 Pin Diagram
    Pass, but there may be something useful in here.... link
  • 01-23-2012 3:08 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hay thanks for the PDF.
    I spoke to my local dealer today and he said just split up the cat 7 cable in the following way.
    1pair - right speaker
    1pair - left speaker
    1pair - for ml sense and to replace pink and blue together.
    1pair - data and -
    Not 100% sure how to ground the cat 7 as the is a shield and not dedicated wires for ground and croning those into junction boxes might be tough.
    Those that have used cat 5 as a cheaper version that masterlink how did you ground the cable?
    Thanks all
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
