Latest post 01-25-2012 3:37 PM by beolion. 3 replies.
Page 1 of 1 (4 items)
  • 01-22-2012 8:43 PM
    • Chasp
    • Not Ranked
    • Joined on 10-22-2008
    • Posts 10
    Beovision 7-55 speakers
    I need some direction on adding or should I state getting my Beolab 4000's to work with the 7-55. I have them hooked and set up and ran the set mode.  However, they don't turn on when the TV is turned on. If I go into Options and select Adjustment and highlight video speakers 2 or 3 the speakers turn on and sound great. When I select store the speakers go into standby. How can I get these things to turn on when I turn the TV on?
    Any help is appreciated.
  • 01-23-2012 6:01 AM In reply to
    • hotknife
    • Top 150 Contributor
    • Joined on 02-03-2008
    • Solingen/Germany
    • Posts 552
    Re: Beovision 7-55 speakers
    You use the BL4000 as rear speakers I assume.
    1, select left/right speaker on rear side of your BL4000 (not line!)
    2, you have used the rear speaker output sockets of BeoSystem 3 of your BV7-55
    3, you select BL4000 in the DSS setup of your BV7-55
    select speaker modes 1-5:
    Mode 1: Stereo centre speakers (subwoofer muted)
    Mode 2: Stereo in L/R speakers (subwoofer is active)
    Mode 3: Dolby 3 stereo
    Mode 4: Dual stereo, stereo in L/R front and rear speakers (subwoofer is active)
    Mode 5: Dolby digital, Dolby Pro-logic, DTS, Dolby 7.1
    That`s it!
    BeoVision 8-40, ATV2, BeoSound 4, Front BeoLab 9, Rear Beolab 4000 MKII, Beo 4
  • 01-23-2012 8:53 AM In reply to
    • Chasp
    • Not Ranked
    • Posts 10
    Thank you very much for your help.
  • 01-25-2012 3:37 PM In reply to
    I have the 4000 as rear in my 7-55 setup with BL9 as front.
    I think that the 4000 are brilliant speakers.
    There is something about B&O.....
