Latest post 01-21-2012 3:25 PM by tompa. 3 replies.
Page 1 of 1 (4 items)
  • 01-21-2012 8:15 AM
    • CJM1
    • Not Ranked
    • Joined on 09-01-2011
    • Posts 35
    TV SCART socket on Avant
    What does the TV scart on the avant do. it has the 3 at the top AV, Video Decoder etc. and then further down the back of the TV there is a TV socket on the left and the video decoder scart socket. What does the TV one do and can i plug a set top box in it?
    Filed under:
  • 01-21-2012 10:49 AM In reply to
    • tompa
    • Top 500 Contributor
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Re: TV SCART socket on Avant
    The Tv and decoder socket you meen is from the internal videorecorder and and tv socket you should have a scart cable to video socket
    higher up on tv set, else video doesn´t work
  • 01-21-2012 2:09 PM In reply to
    • CJM1
    • Not Ranked
    • Posts 35
    the video decoder is plugged in to the video decoder at the top. but there is one empty socket at the bottom that says TV what does it do?
  • 01-21-2012 3:25 PM In reply to
    • tompa
    • Sweden
    • Posts 94
    CJM1:
    Even if that work..It's wrong !
    The right connections are between tv socket on vcr and video socket on the upper connection panel
    AV and Decoder on upper panel is for external sources
    then you have decoder socket on vcr left and that should be empty (the video inside is a standard Philips vcr with that connection and are not used in b&o)
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
