Latest post 01-22-2012 8:29 AM by Søren Hammer. 7 replies.
Page 1 of 1 (8 items)
  • 01-20-2012 6:34 PM
    Beogram for Beocenter 9000...help!!
    Hi...
    I have a Beocenter 9000 and am looking for a Beogram that will be suitable.  Any help would be really appreciated.
    Thanks,
    Steve
  • 01-20-2012 9:45 PM In reply to
    Re: Beogram for Beocenter 9000...help!!
    The Beocenter 9000 works with all beograms without built in RIAA preamplifier. You can remote control the Beogram if it is one of the newer models (after ca. 1980).
    Beograms equipped with Datalink which will enable remote control of functions: Beogram 8000, 8002, 6006, 6002(start/stop only), 3000, 9000, 3300, 9500 and 8500.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-21-2012 11:03 AM In reply to
    Just to add some info, I have a BeoGram 5500 with a BeoCenter 9000 and the Beogram works remotely and automatically.
  • 01-21-2012 6:57 PM In reply to
    A Beogram 9500 would look great with the beocentre!
    BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
  • 01-22-2012 2:07 AM In reply to
    david coyne:
    It is, if the BC9000 has the same mirror finished panels. If not the BG9000 suits better.
    Got all of them incl. 5x BG4500 and most of them for saleWink  My collection is getting out of proportionBig Smile
    My only concern is how to ship them safely.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 01-22-2012 4:06 AM In reply to
    The ones that actually match best are Beogram 3000 or 3300 as they have brushed aluminium dust covers and the sloping front to match the Beocenter 9000.
    And.......they are cheaper to buy!!
    I always thought that the Beogram 9000 was a bit too square looking for the Beocenter.
    Shipping any Beogram is not a problem as long as it is done properly!
    Regards Graham
  • 01-22-2012 4:27 AM In reply to
    joeyboygolf:
    Exactly, same thoughts..
  • 01-22-2012 8:29 AM In reply to
    rkammer:
    Ahh, forgot about the 5005/5500, I even had one myself once Wink
