Latest post 01-19-2012 3:24 PM by Stoobietoo. 2 replies.
Page 1 of 1 (3 items)
  • 01-19-2012 3:38 AM
    Beolink 1000 battery leak
    I have a beolink 1000. After a few days the batteries are empty. I've opened it, bur everything looks "OK", I can't see anything suspicious. What's wrong?
    Filed under:
  • 01-19-2012 4:20 AM In reply to
    Re: Beolink 1000 battery leak
    Keypad button stuck down?  Can you check if the IR is sending constant signals by looking through a digital camera at the IR emitters.  You'll see it flashing with a signal.
    Am I ready? I was born ready!
  • 01-19-2012 3:24 PM In reply to
    See my posting 1/2 way down this thread. It is not dealing with your exact issue but it might reset/clear the issue your Beolink 1000.
    Here
    Good luck
    Stoobie
