Latest post 01-18-2012 10:01 PM by Søren Mexico. 2 replies.
Page 1 of 1 (3 items)
  • 01-17-2012 10:00 PM
    B & O 5500 control panel
    I have a 5500 control panel that's ceased working. Is there somewhere I can send it for repair, or a current model that will work a 1987 system?
    Filed under:
  • 01-18-2012 3:55 AM In reply to
    Re: B & O 5500 control panel
    The Beosystem 5500 can be remote controlled by all later B&O remotes; Beolink 1000, Beolink 5000, Beo4, Beolink 7000, Master control panel 6500, Beo5 and Beo6.
    I would suggest to see if it's possible to get your MCP repaired, maybe at your local B&O shop.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-18-2012 10:01 PM In reply to
    Where are you situated, these Control panels are not to difficault to repair.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
