Latest post 01-15-2012 7:39 AM by Dennis. 4 replies.
Page 1 of 1 (5 items)
  • 01-15-2012 4:11 AM
    • beopuig
    • Not Ranked
    • Joined on 03-28-2010
    • Barcelona-Catalonia
    • Posts 68
    Balance problems. Help!
    Something is wrong with my Beomaster 4500. When I press the Balance key maximum to the left speaker it is ok but when I press maximum to the right both speakers are mute. Then I played a stereo test and it appears that the system is on mono. Any ideas?    Regards
  • 01-15-2012 6:31 AM In reply to
    • beopuig
    • Not Ranked
    • Posts 68
    Re: Balance problems. Help!
    More clues. This problem only happens when I use active speakers. It is ok if I use the 2-pins plug for passive speakers.
  • 01-15-2012 6:49 AM In reply to
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    That it only happens with active speakers is important in this situation! Wink Take a look at the back or the underside of your right speaker - I'm 99% (Read 100%) sure that the position switch is set to L (Left). Switch it to R (Right) and the problem should be solved. Smile
    - Dennis
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
  • 01-15-2012 7:30 AM In reply to
    • beopuig
    • Not Ranked
    • Posts 68
    Dennis:
    - Dennis
    Hi Dennis, You are absolutely right. Problem solved.
    Thanks a lot for your help
    Joan  ;)
  • 01-15-2012 7:39 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    beopuig:
    Joan  ;)
    You're welcome. Glad to hear that it solved the problem. Smile
    - Dennis
