Latest post 01-15-2012 3:23 AM by Leslie. 1 replies.
Page 1 of 1 (2 items)
  • 01-14-2012 7:14 PM
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    250V Fuse for a U.S.-Spec LC1?
    I recently picked up two LC1 light controllers, neither of which work (won't react to remote; touching metal top does nothing).  Suspecting the fuses might be blown, I removed both of them.  They look fine, but they're not identical, and both are labelled 250V / 3A.  Is this normal for a U.S.-spec. LC1?  (plug and Type/voltage shown on label are U.S.-spec).
    Will the fuses work for 110V or should I replace them?  I'd like to replace them since I've heard that fuses can be bad even if they look good.  But with what specification fuse?
    T.I.A.
  • 01-15-2012 3:23 AM In reply to
    Re: 250V Fuse for a U.S.-Spec LC1?
    Hi Bob, as far as I know most of these type of fuses are "labeled" with 220V and to me the fuses still looks okay. The fault must be something else I'm afraid!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
