Latest post 01-13-2012 2:16 PM by Doctor. 2 replies.
Page 1 of 1 (3 items)
  • 01-13-2012 9:40 AM
    • Clived
    • Not Ranked
    • Joined on 12-15-2011
    • Posts 1
    Pre-amp for Beogram 4000
    The company that sold these doesn't seem to have any in stock.  Any suggestions?
    Filed under:
  • 01-13-2012 11:35 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Pre-amp for Beogram 4000
    What exactly are you after? It was only the 6000 and some later tangentials that had phono preamps. The 4000 never had that option.
    Olly.
  • 01-13-2012 2:16 PM In reply to
    I guess he is looking for a suitable RIAA. You can get one from a number of sources - Have a search on eBay or approach one of the re-sellers. About £50 will get you something perfectly decent - you can spend whatever you want though - the cheapest are about £12 - the most expensive £000s!
