treminaor:Also it seems as if the Beogram 4000 and 8000 TT's are the most popular on here... how do these tables compare to a TX?
Most B&O lovers view the Beogram 4000 as the finest, purely B&O turntable of them all, both from the point of view of sound and build quality and the integrity of Jensen's and Pramanik's design thinking. The 8000 and its successor the 8002 were technically adventurous with the use of a different electronic direct drive system and although the build quality isn't as good as the 4000, some think the 8002, particularly with its improved record damping from the platter design, sounds even better than the 4000.
How does the TX compare? Well, it shares the same type of platter as the 8002 and to quote the comments on the relevant 'products' page on this site for the BG 6002, effectively an identical deck to the TX -
"This is an under rated deck. In many ways this can be seen as a Beogram 4004 with the design of a Beogram 6006. It is belt drive and much simpler than the equivalent Beogram 8000. As such it is actually rather reliable and performs very well."
Given that I suspect the author is Peter, an authoritative and long-established Beoworld member who has owned just about every worthwhile deck B&O produced, I would be prepared to take his word on the performance of the TX.
Owning both an BG 8002 and BG 6500, and with both fitted with an MMC2, I can, just about, hear a difference between the 8002 and the 6500, but then I am geeting old and the hearing is going. But this might indicate that the TX is a better deck than the more recent tangentials, and with the MMC2 you have, would compare well with the 8002.
Cleve
