Latest post 01-12-2012 8:13 AM by hamarfenton. 2 replies.
Page 1 of 1 (3 items)
  • 01-12-2012 6:45 AM
    Reattaching Glass Panel on my BeoCenter 9000
    Hello there!
    I have a BeoCenter 9000 that has served me very well for the last ten years and is in excellent condition. I have recently purchased a BeoSound 9000 and its time for the BeoCenter to move on.
    Before selling I need to re attach the lower front glass control panel, although this works perfectly, the glue has dried out and the panel is loose.
    Has anyone reattached this themselves and if so can you offer any advice as to what adhesive to use and how to remove the old adhesive tape (if necessary!)
    Thanks in advance!
  • 01-12-2012 7:14 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: Reattaching Glass Panel on my BeoCenter 9000
    I used super glue gel - the gel is best because it does not drip anywhere.  I did this for both my BC9500 and my mother in law's a couple of year's ago and have had no problems since.  I didn't remove the old tape.
    Some advice is available here (http://forum.beoworld.org/forums/p/37641/312605.aspx#312605
    and in other threads.
  • 01-12-2012 8:13 AM In reply to
    Thanks much indeed mate, I'll pick some up tonight and have a go at fixing it!
    Many thanks for your time!
