Latest post 01-24-2012 7:48 PM by Søren Mexico. 5 replies.
Page 1 of 1 (6 items)
  • 01-11-2012 9:29 AM
    Beogram 1202 & Beomaster 901 stereo/mono issue
    Hi guys, I've got my folks old Beogram 1202 & Beomaster 901 up and running with a pair of Beovox 1702 speakers, now the only trouble I have is the with stereo /mono. I know both speakers are working clearly as I've tried them in left and right outputs in the beomaster but, with the mono button off on the beomaster sound only comes from the left hand speaker, whether the source be turntable or radio which leads me to believe its not the cartridge on the turntable.
    On pressing the mono button on the beomaster both speakers come on but it seems they are both playing the same mono signal as stereo records are missing the usual sounds, backing vox, guitar solos etc
    Any thoughts on what the issue could be?
    Cheers in advance!
  • 01-11-2012 11:03 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beogram 1202 & Beomaster 901 stereo/mono issue
    I'll help - but I want pictures of your items in return! Devil
    You have 2 of my favorite vintage (1202, 1702) items together! Once we get this up and running, I want to hear some thoughts on those speakers. Please!
    Ahem, anyway -
    My initial advice would be to clean the speaker switches - a common problem on old gear. Deoxit or some other contact cleaner will work just fine.
    Evan
  • 01-11-2012 12:25 PM In reply to
    haha well pictures are something I can definately do....
  • 01-11-2012 12:59 PM In reply to
    Should be some pix here for your viewing pleasure!
    http://www.flickr.com/photos/74128425@N06/6679812657/
    Enjoy! I'll buy some switch cleaner tomorrow n see what happens!
  • 01-12-2012 12:40 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Brilliant! Yes -  thumbs up Thank you very much! Those pieces look like they were made for each other or something. haha
    Those 1702s are bigger than I imagined Hmm
    Good luck with the cleaning!
    Evan
  • 01-24-2012 7:48 PM In reply to
    Kind of old thread, but anyway, if your 901 is not reconditioned, do it, dont mess to much around with your contact cleaner, it will only spread the sh1t to where you dont want it, check here and here, if the caps wasn't changed in the speaker crossovers, do it, it does a lot to the sound, gets clearer and not so muffled. Tell us what happens, we like to help, but we also like to see results, good pics by the way, I like that BG 1200, I want one.Big Smile
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
