Latest post 01-11-2012 9:28 AM by danezro. 2 replies.
Page 1 of 1 (3 items)
  • 01-11-2012 8:52 AM
    BEO6 "USB Connecting" message
    Does anyone know if there is a way to reset a BEO6?
    I tried updating a playlists and for the last hour the screen displays "USB Connecting".  I have now physically removed the cable from my PC but the message is still there - am I going to have to wait for the battery to die?
    I have tried holding different buttons down for 5seconds and that doesn’t do anything!!
    Dan
    Filed under:
  • 01-11-2012 9:12 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BEO6 "USB Connecting" message
    Try pressing STANDBY and SELECT simultaneously for some seconds.
    Should power down your Beo6...
    Stefan
  • 01-11-2012 9:28 AM In reply to
    Thanks for the reply.
    I wasn't sure which buttons were "standby" and "select" so looked at the manual held on the Beoworld main site and although it didn't work by holding them down, the manual points to a reset button next to the cable input.
    Typical bloke not reading manuals, BEO6 is happy again and so am I!!
