1st March February 2012
Latest post 01-22-2012 1:26 PM by tournedos. 30 replies.
01-08-2012 1:13 PM
Rapidroy
- Joined on 03-07-2008
- Posts 35
Hi all
I just got a 4004 and when I press start then 45 but the tone arm stops at the 33 size?
Roy
Rich
- Joined on 07-11-2010
- Orlando, Florida, USA
- Posts 1,089
Re: 4004 can't find a 45?
If the 4004 works like my 4002, you should just press start after placing a 33 rpm LP or a 45 rpm single on the deck. The deck will start at 33 rpm, then move the tonearm over and sense with a light whether you have an LP or single on the platter. (Is your platter original? Are you using an aftermarket mat on the platter? Is the light on the tonearm working?)
If the deck senses the LP, the tonearm will drop in the lead in groove. If the deck does not sense an LP, it will continue moving toward the single, speed up to 45 rpm automatically, then drop the tonearm into the lead in groove when the light senses the single.
If this is not how your deck works, post some pictures.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
In some deck types (there are countless versions) it is an infrared
LED, which would obviously be invisible in operation, and will show open
on resistance measurement. Try looking at it with a cell phone camera,
you might see it lit up then.
If you can confirm that it is instead an incandescent bulb and
doesn't light, it needs to be replaced. It should glow when ever the
table is turning.
Anyway, if the arm works automatically on 33, I
think you can forget about this particular sensor for now, as it is
apparently working. Do you have a light at the sensor arm (with the
B&O logo)?
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
Have you got a meter? Are you comfortable taking measurements and following a circuit diagram?
Could be a loose connection between sensor / detector circuit, the detector circuit itself (dry joints / faulty capacitor etc.), the sensor (a small PV cell) or something else.
Step1
- Manchester
- Posts 961
That is a postion detector, and tells the beogram where the start point of a 33 / 45 record is. This is not your problem as the beogram is landing on the 33 spot which is why you should ignore this. This ruler, along with the sensor arm is like an AND gate. If both points are 'active' while the arm traverses the record then that marks the point where the arm should drop.
Now, the fact that your arm is dropping at the 33 point clearly means the deck cannot, for whatever reason see the pulses from the sensor arm. So, the fault is most likely somewhere between the sensor and output of the detector circuit.
Before you look here though, is there a nice clear spot of light on the platter below the sensor arm?
tournedos
- Finland
- Posts 5,808
Rapidroy: I have the service manual but it does not have a full schematic. I don't think anyone has a FULL schematic for this TT.
The same place where you found that document, which is stolen from this site, probably hosts other service manuals stolen from this site as well, so look for 4002 too. The 4004 is very similar to the later DC motored 4002's, with the addition of the simple remote control logic.
There are numerous minor revisions of each model, so be flexible when reading the diagrams, as the component numbers don't always match.
Rapidroy: what does "Rep. BL " mean?
It means to replace that component, I think. But you shouldn't blindly follow the troubleshooting diagrams, as just like any service manual, they were designed to help when these decks were new. Old age problems can manifest themselves differently, often in ways nobody could see coming decades ago. Replacing caps that are obviously faulty should be a good start.
Ultimately, you need to follow the signal from the detector arm and see where it gets lost. It can't see the ribs on the platter now, and the problem can be as basic as a too weak or optically mislocated bulb. It is unfortunately quite hard to get right without an oscilloscope. The full schematic shows oscillograms at several points in the amplifier circuit.
Step1
- Manchester
- Posts 961
Firstly, it would be great if you helped this site and became a silver member (or gold with fantastic benefits) and then you would have access to the diagrams.
Now, a quick way of tracking the fault either side of the detector circuit is to disconnect the detector lamp from the circuit. I recomend removing one of the wires that terminate on the pcb near the solenoid (please insulate and safely tuck away). If the arm still drops then it is a problem with logic. If the arm does not drop it is a problem with the detector circuit.
As Mika suggested an oscilloscope is required to fault find, however testing / replacing the electros in the faulty section is possibly your only option. Just do so carefully and methodically to minimise the introduction of new faults!!
mean't to add capacitor kit is available from Martin (user name Dillen)
Rapidroy
- Posts 35
I disconnect the light in the arm, pressed START (nothing on platter) platter spun up to speed, tone arm moved to edge of platter and dropped tonearm at the 33 area. I picked up a couple caps that load up to tell the arm stay up or drop down, the ESR meter showed being marginal I'll give them a try later today.
btw: I was a paid member but money is a little tight right now, I did try to pay but they don't take PayPal (I sold some stuff and my PP account has a few bucks in it).
Rapidroy
- Posts 35
I changed
1c19 4.7
1c20 1.0
1c21 4.7
no change in operation. darn. I like to change things one thing at a time, then test to make sure I haven't made things worse.
