Latest post 01-06-2012 4:57 AM by chartz. 4 replies.
Page 1 of 1 (5 items)
  • 01-04-2012 5:16 PM
    • Gene
    • Not Ranked
    • Joined on 09-17-2011
    • Topeka, Kansas USA
    • Posts 26
    Beogram CD3300 Lid won't open.
    My Beogram CD3300 was operating perfectly until recently. Now after not using it for some time, when I push the "eject" button, the lid will not open. It rises a tiny bit, but needs to be manually lifted the rest of the way. I have it on my bench now with the bottom removed, but I don't see any obvious faults. Any ideas?
  • 01-05-2012 12:16 AM In reply to
    Re: Beogram CD3300 Lid won't open.
    Probably the belt needs changing. It will still look good but won't function anymore. The replacement belt I used was 46mm, 1.4mm. Dillen can probably supply one!
  • 01-05-2012 2:25 AM In reply to
    • Gene
    • Not Ranked
    • Posts 26
    The only belt I see is on the opposite side attached to a motor. Is there another or is that the belt you are referring to?
  • 01-05-2012 4:43 PM In reply to
    There is just one belt in the machine, doing the opening and closing of the lid. If I remember correctly it's next to a motor and some gears. That's the one!
  • 01-06-2012 4:57 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Yes, the belt. But the lid mechanism also works with a microswitch which can also be faulty. Or the lid can get misadjusted with time.
    But try the belt first, although you will find it painful to do!
    Jacques
