Latest post 01-06-2012 6:23 PM by elephant. 19 replies.
Page 1 of 1 (20 items)
  • 01-04-2012 4:52 PM
    • Yendys
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Sydney Australia
    • Posts 100
    BeoPlayer App updated 1.2.4 released
    It just says bug fixes for iOS 5...
    BV10, AvantDVD, BS3000, BL8000, BL6000, BL4000, BL3500, BeoPorts, BC9300, BC7002, CX100s, C75s, Beo4s, BC6000s, LC2s, A9, A8s,
  • 01-04-2012 5:18 PM In reply to
    Re: BeoPlayer App updated 1.2.4 released
    Thanks !
    Download & update worked fine.
    Had a mild panic attack when there was a slight glitch when I first invoked Airplay to the ATV2 but after that it was fine - not that I had noticed any iOS5 bugs anyway !
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
    PS all my stations are still in the list; switching between them without problems ... just the 5 second buffering period.
  • 01-04-2012 5:24 PM In reply to
    • Yendys
    • Sydney Australia
    • Posts 100
    Can also confirm the clock now works for me which it didn't do on the previous version (on iOS 5 devices)
  • 01-04-2012 8:59 PM In reply to
    I'm glad they worked the clock problem, but that really seemed to take a long time to address.
    BeoSystem 5000 (BM 5000, BG 5005, BC 5000, CD50), BeoCenter 3500, BeoCenter 2500, BeoLab 2500, BeoVox S-45, S-45.2, RL-140, CX-100, CX-50, C-75, 3 MCL82 link rooms, A8, 4001 relay and ambio
  • 01-05-2012 8:37 AM In reply to
    These are all of the resolved issues
    1.Must press PLAY twice after PAUSE
    2.BeoPlayer app shuts down when selecting music from the iPhone
    3.Clock time does not synchronise with system time while staying on same "Clock" screen
    4.Alarm cannot be stopped on iPhone 4S
  • 01-05-2012 1:19 PM In reply to
    None of the BBC radio stations are working :-(
    Radio 2 is all I use(d) it for.
  • 01-05-2012 3:11 PM In reply to
    Sevilsivle:
    I checked on my iPad and looked under "United Kingdom" in Browse mode and found under "B" a bunch of them ranging from BBCArabic to "BBC World Service News" that included "BBC Radio 2"
  • 01-05-2012 4:34 PM In reply to
    elephant:
    Sevilsivle:
    I then did some testing (by the way use Search to find "BBC" rather than the long winded way I used first) and found that:
    1. the BBC stations I tested went "buffering", "retry", buffering", retry" until I got bored and did not play
    2. the exception was BBC World Service
    3. interesting, I had similar problems with a number of other UK stations, and
    4. (I know this does not make sense with internet protocols as opposed to shortwave radio) the were all faint (low volume)
    5. whereas other stations around the globe were good volume with good "signal" (connectivity) including the Netherlands, Germany, France, Italy, and Portland, Oregan
    So I hope you have better luck being "closer" to the source
  • 01-05-2012 6:04 PM In reply to
    That is exactly what I meant by not "working"
    I tried BBC 2 via Safari on my iPhone and it worked immediately. My BBC widget on my iMac also still works so the problem must be with the App itself. I have also reloaded it, just in case. Lets hope the station list can be updated wihout B&O having to submit to to Apple for review.
    Tim
  • 01-06-2012 1:29 AM In reply to
    The streaming format of the BBC stations is not supported with the beoplayer.
    B&O should narrow down their list of stations in their app.
  • 01-06-2012 2:06 AM In reply to
    DoubleU:
    Or better still:
    1. broaden their support, and
    2. add informative messages for when they recieve a stream they do not support
  • 01-06-2012 3:30 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    I just use TuneIn radio (even bought the app) on my iPad connected to my BS8. Never really start the BeoPlayer app. It's yet another software product from B&O which is substandard, even though they outsourced development!
  • 01-06-2012 4:08 AM In reply to
    DoubleU:
    Until the latest update it worked, and the Beeb has not changed the streaming format.
    The App itself does not need to support the format, iOS5 does.
    I think the links the App uses must be wrong somehow.
    Tim
  • 01-06-2012 5:19 AM In reply to
    Sevilsivle:
    DoubleU:
    Tim
    Thanks for the idea Tim !
    I checked my other radio app but it did not have the BBC, so I downloaded a new app, called "tunein radio", and checked its access to BBC2 and voila !!
    it worked :-)
  • 01-06-2012 7:45 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    elephant:
    it worked :-)
    Yep, see my post above. LOL. I even bought the Pro version as it's an app that works, without fault. Perhaps B&O should outsource development to reliable app developers such as these guys?
  • 01-06-2012 2:09 PM In reply to
    moxxey:
    sorry mate! I missed seeing your post
  • 01-06-2012 2:50 PM In reply to
    BeoPlayer is just about the only app I have deleted from my iGear. Sad
    I can, however, give "two thumbs up" to the TuneIn Radio app mentioned above.
    Just this past Sunday, wifey and I were desperate to get a live feed of an NFL game not being televised in our area. A little googling and I came up with this particular app as a possibility.
    Wifey said: "Wait a minute, I have that app!"
    In less than 30 seconds and a few clicks, we had our game!
    • B&o bottle opener
  • 01-06-2012 3:49 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    BTW guys, one tip from me is to get that Airfoil speakers app. It's superb. You can hijack audio from any source on your computer, then use your iPhone/iPad as a remote speaker (or, if it's docked, the dock speaker). I use this system to push Flash-based password controlled radio (for my football team) to my BS8, via the iPad, using Airfoil speaker app.
    However, you could also do the same for your favourite radio station. Use your laptop to control the feed and push the sound to your iPhone/iPad via Airfoil speakers.
  • 01-06-2012 6:23 PM In reply to
    moxxey:
    Yes, I have been expermienting with it on and off; as well as AirFlick.
    Ideally it should be built into the Apple infrastructure
