Latest post 01-04-2012 4:35 PM by Vifa. 4 replies.
Page 1 of 1 (5 items)
  • 01-04-2012 1:49 PM
    • Vifa
    • Not Ranked
    • Joined on 05-24-2008
    • Posts 64
    LX6000 and Commodore VIC-20
    I have some problems connecting my Commodore VIC-20 to my LX6000. The Commodore is connected to the TV via an antenna signal, but I can't manage to get the Commodore to show up on the TV. I have another Panasonic TV where I just have to push AV and then it shows up. I am not even sure what to push, I think I have tried almost everything.
    Do I need to set up something on the TV before ?
    Best Regards
    Vifa
  • 01-04-2012 2:31 PM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Re: LX6000 and Commodore VIC-20
    You need to tune in to the channel the VIC 20 is "broadcasting" its signal on like it was a TV channel.
    Alternatively you can get a video cable like this http://www.ebay.com/itm/Commodore-VIC-20-High-Quality-Scart-Lead-Cable-/260726018376?pt=UK_VintageComputing_RL&hash=item3cb47b5148#ht_2923wt_1413
    In adition you will get a better picture than with the RF modulator.
  • 01-04-2012 2:52 PM In reply to
    • Vifa
    • Not Ranked
    • Posts 64
    I tried to do a search through the frequencies, but I didn't pick up anything ?- will try another modulator then.
    I have two places on the back of the TV where I can connect the antenna signal, what is the difference beetween the two ?
  • 01-04-2012 3:09 PM In reply to
    • madskp
    • Denmark
    • Posts 111
    • Gold Member
    the on to use should be marked UHF and VHF.
    The other one is probably for an inbuilt satelite reciever (it will be sorounded by a lot of other connectors) and will not be usefull for your purpose
  • 01-04-2012 4:35 PM In reply to
    • Vifa
    • Not Ranked
    • Posts 64
    I managed to get it to work now, I appreciate the help, thanks :-)
