Latest post 01-30-2012 6:27 PM by LC. 4 replies.
Page 1 of 1 (5 items)
  • 01-04-2012 7:53 AM
    • LC
    • Not Ranked
    • Joined on 11-23-2010
    • London
    • Posts 24
    • Silver Member
    Virgin New tivo box xml
    Happy new year to you all
    Does anyone have an xml file for the new virgin tivo box so i can directly control it using my beo6?
    Much appreciated
  • 01-06-2012 4:16 PM In reply to
    Re: Virgin New tivo box xml
    A Happy New Year to you as well.
    I have created what I believe will work with a Virgin Media TiVo and you can download it HERE
    Please update us on how well it works
    Regards Keith....
  • 01-07-2012 6:21 AM In reply to
    • LC
    • Not Ranked
    • London
    • Posts 24
    • Silver Member
    Thanks a lot for that keith, i will give it a go and let you know how it works.
    I have made a few xmls my self which i am happy to share however my buttons are allways on the touch screen and then i manually copy them to the hard keys. Is there a way i can do all this within the xml?
    as at the moment i have to manually copy to each of the hard keys everytime i do a new config. Hope that makes sense to you?
    Thanks again
    Louis
  • 01-07-2012 4:41 PM In reply to
    If you send me the XML files you have made yourself to keith@beoworld.org I will return them with the hard keys pre-assigned.
    I do not copy-n-paste as has been suggested, that would take much to much time..
    Regards Keith....
  • 01-30-2012 6:27 PM In reply to
    • LC
    • Not Ranked
    • London
    • Posts 24
    • Silver Member
    Hi Keith,
    Sorry for the slow reply been flat out busy! The Virgin Tivo XML worked perfectly.
    Thanks for that. I will send you all the XML's i have made as soon as i get 5 mins this week.
    Thanks for your help!
    Louis
