1st March February 2012
Latest post 01-06-2012 11:56 AM by a2bur. 9 replies.
01-03-2012 9:24 AM
a2bur
- Joined on 04-20-2007
- Posts 262
upgrade my BeoVision5 to HD
Hi all . Want to upgrade my BeoVision 5 setup to HD , but with the relative low price of panels I can’t justify the high B&o tv prices any more . So I propose to hang a Samsung 46” screen on the front of the 5 , You might gasp in horror but my 5 is in a built in unit and can only be viewed from the front so would not look odd or out of place . I want to use the 5 as a BeoSystem 3 so will disconnect the 5’s screen and use it to drive all my Lab speakers and control the Sky with the B&o remote , also have a 7000 connected and master link Tv in the bedroom above . The Samsung screen will be direct to the Sky box via HDMI , so the only thing I will have to do is turn on/off the Samsung screen , but could program my Beo5 to do that . Should be able to connect an RF feed to the Samsung from the 5 so I can view the B&o menus when needed . the only problem I can think of is a possible sound lag because the 5 will be processing sound thru the Scart , dose anyone think this will be a problem or any other things I haven’t thought of ?
Richard
Any thoughts also on connecting a Blu-ray player , HDMI direct to the Samsung for picture but how to connect for sound ?
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
Re: upgrade my BeoVision5 to HD
That sounds like quite a project..
Try and post some before and after photo's if you can
Regards,
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
a2bur
- Posts 262
Could change the panel , but quite involved . Not got a lot of room around the 5 , because the frame is very narrow on the Samsung the width on a 46” is the same , so gain a bit on the screen size .
Sky should work as it is now , connected as it is , just the picture will be shown on the new panel via HDMI . But what connections to use for the sound out of the Blu-ray player into the BV5 , don’t’ have many options into the BV5 , scart , S-Vid , audio left and right ( next to the S-Vid ) and input one and two ( next to the speaker sockets ), Any suggestions what is best ?
Richard
Chris
- Joined on 03-19-2010
- Corbridge, UK
- Posts 353
Having never liked Plasma, i must admit the new generation of NeoPlasma panels are not only very good but excellent value for money.
Back to my generic platform, upgradeable B&O tv thread! A horrible waste if you can't upgrade what is one component part of the 5, albeit an important one.
A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!
a2bur
- Posts 262
The Samsung I am getting tomorrow is a 46” Smart LCD . I have Samsung 3D glasses ( D series panels ) so have stuck with Samsung . My brother-in-law has 50” Plasma and LCD and both are excellent pictures , all be it a bit bright for my taste .
Richard
a2bur
- Posts 262
Is there a Beo remote command to turn the screen off and on ? Don’t’ want the 5’s screen on behind the Samsung panel , but need to have the 5’s screen available for menus and setting ect. Failing that is the screen feed with a cable so I can cut it and put in a plug and socket .
Richard
MartinW
- Joined on 11-01-2007
- Posts 84
Last time we upgraded a BV5 from non HD to HD we just updated the panel inside the Bv5 to a new HD Panasonic panel, perfect results, 2 HD inputs to the screen, worked exactly as it used to. Cost was just under £1900. Customer was very happy with his nicely upgraded B&O product.
BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
a2bur
- Posts 262
Got the panel on and control the Sky with the Beo4 as before , got to program my Beo5 the control the Blu-ray and the smart screen . Next I want to disconnect the BV5 screen , hoping I can pull out the screen plug and connect to the new panel so I can see the BV5 menus if ever needed . Got a few more pictures but will only let me add one .
Richard
Page 1 of 1 (10 items)
