Latest post 01-03-2012 5:14 AM by Compostela. 3 replies.
Page 1 of 1 (4 items)
  • 01-02-2012 4:49 PM
    Access to PUC menu
    Hi folks I am swapping a Panasonic Blu ray player with a Playstation on my BV10. I do not seem to have a list of boxes under the Connections menu, just the one Panasonic Blu ray box that I am currently using. The tv was set up for me by the dealer and this included connecting the blu ray player. Is it likely that the dealer simply installed one PUC code rather than the long list I had on my BV3? Or is there some way of seeing the list of boxes so that I can select the PS3 box? Many thanks for any words of wisdom! C
  • 01-02-2012 5:35 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Access to PUC menu
    I think the dealer deleted everything else... Happened to me before... Not very nice but this way you stay in touch ;-)
    Be aware you need some ps3 to b&o converter, re-bl??!
    Search the Forum and you will know...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-03-2012 3:24 AM In reply to
    Keith gave a good explanation in this thread.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 01-03-2012 5:14 AM In reply to
    Thanks guys, very helpful.
    Have a great 2012.
    C
