1st March February 2012
Latest post 01-04-2012 12:39 AM by chucky. 13 replies.
01-01-2012 5:34 PM
palljonsson
- Joined on 12-30-2011
- Posts 5
Hi
I just got BeoLab 8002 speakers and i'm a little neurotic about blowing them out... Is it at all possible to blow out these active speakers? Won't they shut off before playing too loud that it blows them out? Also I had them connected to my computer and unfortunately disconnected the mini jack without turning them off and there was a large popping sound, can that blow them out?
Thanks a lot for all answers!
Palli
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
Re: Blowing out BeoLab 8002
B&O stuff is usually well protected - the green/red light goes amber if there has been an issue.
But why take unnecessary chances? Treat them with care and they will last a decade or two.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
palljonsson
- Posts 5
Believe me, I'm not taking any chances, I'm just wondering... And I pulled the mini jack accidentally, but won't do that again!
But mainly I just listen to the speakers a very loud sometimes (when there's a good song) and I'm nervous about blowing them out...
Dennis
- Joined on 02-01-2009
- Denmark
- Posts 172
A golden rule is: Play as loud as it sounds good (Is that a sentence? ). If the speakers begin to distort when you turn up the volume, then turn the volume down again - Simply as that.
- Dennis
I was borned with a Beolink 1000 in my hand!
Ever seen a Beomaster 6001? I have one! Look here.
Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
Wish list: Beolab 2,
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
I think the ABL gizmo will keep them in working order for a long time to come.
Removing the mini plug will likely damage the tweeters, if anything. I would still avoid it.
As others have said, don't worry, you will be fine.
Hungedu
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
I've had a pair of first generation (BeoLab 8000) speakers since 1994. They've never blown or needed any service, and I use them constantly with very loud music and movies.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Distortion as mentioned is really the key to knowing when your speakers are outside the "comfort zone".
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
f5434964
- Joined on 07-21-2010
- Posts 198
my BL8000 (MkII) produce an "vibrating" sound playing loud music, it come from the "cloth"/grille/covers in front of the bass "air" outlet (top of the speaker); I do not like it but I can not find a way to stop it (only tightening the grille by hand which is a bit frustrating)
the drivers themself look ok - so I do not thinks the sound occurs from any other part of the speaker...
does anyone have a similar problem?
Regards Elmar
Sevilsivle
- Joined on 02-15-2009
- Germany
- Posts 40
May be my reasoning is too simplistic, but being an active loudspeaker surely B&O wouldn't give it enough power to do any damage to itself?
That would be a bit like building a car with an engine powerful enough to break the driveshaft when you put your foot down.
Tim
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
Sevilsivle:
Tim
Yeah, thats what I was thinking too...
Surely B&O when building the loudspeaker would only use drivers that could handle the amplification capacity of the unit itself ....? Surely all the drivers used in the Beolab 8002 should be able to handle the maximum volume the speaker is able to reach...?
Regards,
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
chucky
- Joined on 05-03-2007
- Posts 266
I got my Beolabs 9 in orange... So active or not it is possible to blow them up. ( green playing, red is out and the orange light means are you mad???) No damage though. Chucky
Wanna play?!! (Also a PRIZEWINNER ON BEOWORLD!)
Page 1 of 1 (14 items)
