Hello!
Just bought a AUX cable for christmas to my parents for use in they'r BO-system. The cable was a 3,5 mm pin in one end, and a plug to put in the Beocenter 2300 in the other.
I have:
Found the correct slot, and put the BeoCenter 2300 into AUX.
I have not:
Programmed the Beo4 remote for use with AUX, i wanted just to trie it manually on the Beo Center first. (have seen som info regarding this).
My problem is:
I cannot controll the sound-level directly on the BeoCenter. I can only controll the sound on the mp3-player/ipod/ipad/etc. And it seems like the Beocenter set itself to an extreme high sound-level. So if i would put in a mp3-player and forget to turn down the volume on it(which i will), it would be an un-plesant experience for both me and the speakers :)
Any ways to make the BeoCenter act like a normal Aux slot, were you set the output on the mp3-player high, and controll the volume directly on the BeoCenter. (later to make this work with the remote)
Any help is deeply appreciated!
Regards,
Jan...
