Latest post 01-24-2012 5:22 AM by mr_fruitbat. 10 replies.
Page 1 of 1 (11 items)
  • 12-30-2011 6:11 PM
    Managing content on BS5/BM5 using a Mac
    What is the best way to manage content on the BS5/BM5 using a mac? I can easily add content via Beoconnect, but how do I delete - directly on the mounted BM-Share$ or some other way? Want an easier way than having do any management via the BS5 itself.
  • 12-30-2011 10:01 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Managing content on BS5/BM5 using a Mac
    I'm using Beoplayer on several Macs in the house. Works via Parallels Desktop and Win XP.
    This way I'm also programming my Beo6 and my Lintronic stuff.
    Hope this helps.
    Stefan
  • 12-31-2011 1:27 PM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    The easiest thing I've found is the use the Mac OS and use the Finder function. . just delete right there on the BM Share folder
    I'm ready for something new that I actually want to buy!
  • 01-02-2012 12:55 PM In reply to
    Is there a good way to make playlists in the Finder? I do have a BM1 and with Beoconnect it is not possible to make playlists. In PC mode it takes hours...
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 01-02-2012 3:51 PM In reply to
    mjmedlo:
    Does that affect the MOTS function?
  • 01-03-2012 11:34 AM In reply to
    I am using the Finder function also.  In addition, I rip in the FLAC high quality format on the Mac using the Phile app.
    http://itunes.apple.com/us/app/phile-audio/id413934579?mt=12
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 01-04-2012 3:20 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    I honestly don't know the answer to this question
    MJM
  • 01-07-2012 4:14 PM In reply to
    mjmedlo:
    MJM
    MOTS is triggered and builds an index automatically if files are added.
  • 01-07-2012 8:12 PM In reply to
    Harry2008:
    mjmedlo:
    MJM
    The question was what happens when something is deleted - I would guess/hope the algorithm is also launched when that happens.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-08-2012 5:47 AM In reply to
    elephant:
    No need. If a song is gone, it's gone, and can be simply skipped. That doesn't have to alter the relations of the remaining songs to each other at all.
    -mika
  • 01-24-2012 5:22 AM In reply to
    Hi, I use Chronosync to sync my music directory on my NAS to the music directory on the BM5. Any changes I make within iTunes, I.D tags, artwork or when I add, delete or move tunes to a different folder etc are copied across when I run Chronosync. Works flawlessly.
