Hi
I recently acquired a pair of BeoLab 8002 speakers and I wish to connect them directly to a MacBook Pro computer that serves as a music/tv/media computer. There are two things I'm uncertain of that I'd be very thankful for getting help with :)
First, is the internal soundcard in the MacBook Pro good enough for these speakers (via the mini jack output) or should I get a professional USB soundcard that gets digital output from the computer and sends analog to the speakers?
Second, If I just use the internal soundcard what is the best way to connect the computer to the speaker?
SETUP 1:
I've already got a Male DIN5 to Male Mini Jack like this: http://soundsheavenly.co.uk/ipod.jpg
and a 2 X Female DIN7, 1 X Male DIN7 splitter like this: http://soundsheavenly.co.uk/bando-pl2y.jpg
And i've connected those two together, and then the Male to one 8002 speaker and a Male-Male DIN8 to the other speaker and the last Female DIN7. The problem with this is two-fold. Both speakers are only picking up the left audio signal and also there's major hum or buzz sound at all times.
SETUP 2:
What I'm thinking about getting instead are these cables: http://soundsheavenly.co.uk/bando-lab3.jpg (http://soundsheavenly.co.uk/bando-ipodtolab.htm). So that's Mini Jack to two PowerLink wires that hook up to both speakers (I'm assuming one is wired with left signal and the other wire has the right signal). I'm sure this will fix the left/right signal issues I'm having with SETUP 1 but I'm wondering if there will still be the humming sound and also if the sound quality will be good enough.
Do you guys have any recommendations or tips for me in this regard? I've tried searching the forum but haven't found any post that answers my questions.. :) Thanks in advance for any help!
