Latest post 12-31-2011 8:01 AM by Raeuber. 7 replies.
Page 1 of 1 (8 items)
  • 12-30-2011 4:22 AM
    BV7-32 DVD player in mainroom
    I have a BV7-32 in bedroom. Is it in some way possible to use the internal DVD to watch in my mainroom on my BV9?
  • 12-30-2011 7:44 AM In reply to
    Re: BV7-32 DVD player in mainroom
    do you need to set the bv7 as video master?
    Cheers Nick
  • 12-30-2011 1:35 PM In reply to
    In linkroom you can hear/see all sources of your mainroom, but not the other way.
    But you can program your BV 7 to mainroom and your BV 9 to linkroom, then you can watch DVD from BV 7 on BV 9. Don't forget to change the antenna connections and the RF link amplifier has to be placed in mainroom.
    /Räuber
  • 12-30-2011 5:29 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    By the time you've taken the signal down an RF cable, then magnified it onto a beautiful BV9 - 50" HD screen - it'll look pretty poor in my opinion..
    Lee
  • 12-30-2011 5:43 PM In reply to
    same opinion as grand master lee!
    Without Beonet (I hope I'm right - in a way that it will transmit HD signal) video link nowadays is without use!
    get a PUC controlled external gear!
    Regards Elmar
  • 12-31-2011 5:50 AM In reply to
    you know what I didn't think of that!!  Its a pain for anyone who has a bv9 bv5 or bv4 are stuffed and need to hide a dvd i assume you can control it as long as its on the puc list?  Cheers Nick
  • 12-31-2011 6:26 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    mr_anders_son:
    Should be possible via Av1 port on your 7-32 as long you don't want to control it from the main room.
    The Scart plug must have an output (composite,RGB?) for video recording. Connect this output with a Scart input of your BV9.
    I never tried this constellation, but as far as I know, all Beovisions have an output on Scart AV1. Selected Picture and sound are automatically routed to this port. You don't need HD signal, DVD player is SD.
    Stefan
  • 12-31-2011 8:01 AM In reply to
    stefan:
    mr_anders_son:
    Stefan
    Hi Stefan,
    this should work, but you need a very long scart cable from BV 7 to BV 9.
    BTW: The internal Bluray player of my new BV 7-40 3D distributes the video and audio signal to my BV 10-40 in linkroom via Masterlink (audio) and RF Link (video) with no additional scart connection and of course in SD.
    /Räuber
