Latest post 12-28-2011 2:16 PM by sashaz. 2 replies.
Page 1 of 1 (3 items)
  • 12-28-2011 12:22 PM
    Mastelink cable not outoswitching ML/MCL converter on/off
    I have a overture connected to a ML/MCL convertor and using the mastelink cable only the amp does not switch on/off. Using the powelink the amp does switch on off correctly. Any idea on how to fix this?
  • 12-28-2011 12:38 PM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: Mastelink cable not outoswitching ML/MCL converter on/off
    I think this is by design: When connected by ML the Overture thinks that the ML/MCL is powering speakers in another room, whereas something connected by PL will usually be in the same room.
    Does the ML/MCL go into stand-by after a long press on the remote's off button?
  • 12-28-2011 2:16 PM In reply to
    no with the pl its all instant.
    I thought this is why you cant control the ML/MCL volume with the ir sensor.
