Hi
I have Bc9k, and it doesn´t do anything reasonalbe. It seem to have all voltages it should have, but when plugget in mains, nothing happens, only clikc from relay, no lights, no reaction to anything.
Then if reset wire from amp board to cpu is removed (to float), there is some attempt to reset, but result is random lights on, nothing else. If reset is connected, all functions dissapears (like reset line were active). Line is low, but all voltages before it in circuit are present. Should it be high? If so, I cant see why it isn´t.
I do not have service manual for 9k, only for 9500, is it useful, specially on cpu part and measurements?
