Latest post 12-25-2011 4:21 PM by kumse. 3 replies.
Page 1 of 1 (4 items)
  • 12-24-2011 11:44 AM
    • kumse
    • Not Ranked
    • Joined on 11-09-2008
    • Posts 21
    MX8000.. got the 5 digit manufacturer code, what now?
    Hello out there
    Bought a second hand MX8000 and had it stored for a while. i forgot the code and contacted b&o, they gave me a five digit code, and told me to follow the user guide. The user guide says that i have to look at the CD ROM, which i dont have.
    Do any of you know what i should do with the 5 digit code, when the tv only asks for 4 ?
    Kindly regards
    Thomas
  • 12-24-2011 12:06 PM In reply to
    Re: MX8000.. got the 5 digit manufacturer code, what now?
    Switch the MX 8000 on and Press << on your Beo4 untill the 5th digit shows on your screen. After that enter the mastercode you received.
  • 12-24-2011 5:55 PM In reply to
    • kumse
    • Not Ranked
    • Posts 21
    Thank you Blackrix ! It worked!
    Happy holidays to you!
  • 12-25-2011 4:21 PM In reply to
    • kumse
    • Not Ranked
    • Posts 21
    Blacktrix
    Can you tell me how i activate a new four digit pincode now i have entered the master code?
    Kindly Regards
    Thomas
