Hi Chucky
I have just bought one of these (B&O Version).
It says it works with RF blinds so may work with the Velux RF
(which is quite likely to be made by someone like Somfy as thay make
most RF blind/window controls). However, the guys at JB Media were
extremely helpful and answered my query emails really quickly so you may
want to email them with what setup you have and see what they can
suggest.
I plan to use mine to control all my lights, power
sockets, blinds and curtains, as I have HomeEasy and Somfy stuff round
the place. Currently I use a Philips Pronto Remote to control my lights
etc but wanted B&O compatible as I have a Beo5 and 3 Beo4's that are
begging to be used for Home Automation Control!.
The model that
arrived from JB Media is a newer version than that shown on their site
and is tiny, about 2/3rds the size of a credit card and as thick as your
thumb. It arrived yesterday and has been wrapped by my partner as a
Christmas
Present, so haven't tried it yet. I can't wait! I've been told I cannot
spend all Xmas day & Boxing day playing so roll on Tuesday!! It will
sit on the side almost out of sight. One of the advantages of it is
that it will work from a button press on the B&O remote, or while
you are away it will work off an inbuilt timer all fully programmble on
the PC then disconected and placed where you want!!
Another
advantage is that once you have the controller, at a fairly reasonable
price, the plug in RF sockets etc are easily avaiable and not expensive!
Hope that information is of some use to you
Stoobie
PS. I am nothing to do with JB Media but you may get a pop-up on their site about Java or something! it seems to be becuse they have a christmas snow scene on each page wich runs an older version of Java than on my PC, you may not get the same issue.
