Latest post 12-22-2011 12:01 PM by ajames. 2 replies.
Page 1 of 1 (3 items)
  • 12-22-2011 4:36 AM
    Sony Blu Ray and Avant - Component Video Out Question
    Hi - I want to replace my DVD1 with a Sony Blu Ray player that can play LoveFilm content - I've seen two that will work, I think with my Avant, one has a Yellow Video Out terminal which will definetely work and the other has Red Green Blue and Video - if I get a scart to 4 plug converter will those come through on the Avants DVD input as RGB or will it only work with the Yellow (Composite?) input - in which case I may as well just get the one with the single vrideo out - I know there are problems with component outputs and don't really understand it all! Any help would be much appreciated.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 12-22-2011 11:04 AM In reply to
    Re: Sony Blu Ray and Avant - Component Video Out Question
    The AVANT SCARTS support RGB and that is the best option, see connections
    Regards Keith....
  • 12-22-2011 12:01 PM In reply to
    Great thanks - it;s just that when I'd read that Apple TV can't be connected although that has Red Green and Blue but not the yellow output - anyway, if that will work then that;s excellent
    Thanks again
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
