Latest post 12-22-2011 8:23 AM by jrantala. 4 replies.
Page 1 of 1 (5 items)
  • 12-22-2011 2:30 AM
    Timer recording on Tape2 possible (BM5000) ?
    Just a quick question: is it possible to set timer recordings on Tape2 in Beomaster 5000 ? (Or BM5500, for that matter ?)
    Can't figure out how to do it on MCP5000 and could't find answer in manuals nor searching the forum either...
    - Jari
    Filed under:
  • 12-22-2011 5:00 AM In reply to
    Re: Timer recording on Tape2 possible (BM5000) ?
    Doesn't it work as any other source (RECORD under the flap - TAPE2 - DAY - time - STORE...)? Direct recording to TAPE2 is a bit more complicated, but I don't believe there's anything special to it regarding timers.
    -mika
  • 12-22-2011 5:18 AM In reply to
    Sorry, I wasn't clear enough. It is just timer recording TO tape2 that I'm asking. I suppose it is not possible at all...?
    - Jari
  • 12-22-2011 5:35 AM In reply to
    Oh, you were clear enough - I wasn't thinking Big Smile
    No, I don't think it's possible, except perhaps when the source is TAPE1 - that could make some sense if it's something else than a tape recorder.
    Timer recording to TAPE2 is possible on BS6500. On that, you select CONTROL-TAPE2 before the rest of the programming sequence. I don't believe it works on the 5000 as it's not mentioned in the manuals, but worth a try I guess...
    -mika
  • 12-22-2011 8:23 AM In reply to
    Tried it; not working on BM5000!
    Just have to live with it...
    - Jari
