Latest post 12-21-2011 6:07 AM by kallasr. 3 replies.
Page 1 of 1 (4 items)
  • 12-20-2011 1:45 PM
    IS IT POSSIBLE TO CONNECT OUVERTURE TO CX 100?
    Hallo
    I've a question: is it possible to connect an Ouverture to B&O passive speakers like CX100?
  • 12-20-2011 2:05 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: IS IT POSSIBLE TO CONNECT OUVERTURE TO CX 100?
    You need some amplifier, B&O recommands MCL2P.
    Search the forum for this.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 12-20-2011 5:31 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    kallasr:
    MCL2P is out of production since years, the recent version is called "ML/MCL Converter"
    Both versions will need a fully mounted PowerLink cable.
  • 12-21-2011 6:07 AM In reply to
    • kallasr
    • Posts 1,077
    Vienna,
    you are right! Now the ML/MCL Converter is there (or Beolink Passive without the IR eye).
    But amagian could try to get a used MCL2P... CX100 and Ouverture are out of production since some years, too.
    Smile
    Ralf
