Latest post 12-20-2011 9:17 AM by pawellot. 2 replies.
Page 1 of 1 (3 items)
  • 12-20-2011 6:28 AM
    problem with volume - MLGT
    hi
    I have problem with control volume in my BV7 mk I
    configuration:
    Masterlink Gateway control with savant system (connection with Lan cable)
    TV1: BV7 mk III (master)
    TV2: BV7 mk I (slave)
    I have full control of iPad (savant aplication) on TV1 but in TV2 I can only switch on and change source (I can't switch off and change volume level)
    Do you know what the problem is?
    thanks for help and sorry for my english but I hope that you understand what the problem
  • 12-20-2011 8:32 AM In reply to
    Re: problem with volume - MLGT
    pull out everything from electricity and then reenter after at least 45 seconds
    i hope it helps
  • 12-20-2011 9:17 AM In reply to
    I tried, but still dont work
    this may be a problem with the ML gateway software?mayby ML gateway send wrong commands?
