I am assume one could use a BeoMaster 5 with a BeoSystem 1 setup seeing that the BeoSound 5 Installation Guide lists BeoSystem 1 MKII (940x) & BeoSystem 1 MKIII (9431-9436) within the resolution table with output resolutions available when setting up screen resolution.
I am curious as to what connection and setting one need to utilize in order to do this. I assume that ones BeoSystem 1 (BS1) would have to have PC setup as one of it's external sources?
But then which connections one would utilize in connecting the BM5 to the BS1 setup? Or would the video just go straight out from the BM5 to the BV4?
Anyone shed some light on this setup?
Hiller
BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
