Latest post 12-18-2011 4:39 PM by Beobuddy. 4 replies.
Page 1 of 1 (5 items)
  • 12-18-2011 4:34 AM
    BC2500/Ouverture contact folie
    Heeft iemand nog een "slopertje" liggen van een Ouverture/BC2500? Ik ben op zoek naar het deel wat onder het toetsenbord ligt ofwel contact folie.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-18-2011 7:32 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: BC2500/Ouverture contact folie
    A new foil is available as a spare from B&O - I fitted one to my son's BC2300 a couple of years ago because a couple of the buttons didn't work.  It comes with a set of screws to refit the back plate once you have removed the plastic welds to disassemble.  I think it cost about £30.
    Guy
  • 12-18-2011 9:22 AM In reply to
    Thanks Guy, Graham already told me that it has the same partnr. as the Ouverture so probably still available. Will check, although dealers are not so keen as it comes to selling small parts.
  • 12-18-2011 2:57 PM In reply to
    • Paul
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Leslie, Ton Kuylenburg at Haarlem does not make any problem to order parts........
  • 12-18-2011 4:39 PM In reply to
    So does Fred Baak in Houten not. Never had any problems ordering small (amounts of) parts.
