Latest post 12-18-2011 1:24 PM by Step1. 9 replies.
Page 1 of 1 (10 items)
  • 12-17-2011 12:25 PM
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    BM3300 NTC resistor
    Does anybody know the typical value for R160 in a BM3300?  It's the NTC thermistor in the power fail circuit.
    The receiver has had new amp module and been re-capped but the power fail keep activating at startup Sad
    The voltage values around across the load resisitors R218 & R418 look good i.e. 0v which really only leaves the bias on TR33...
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
  • 12-17-2011 1:07 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: BM3300 NTC resistor
    I would personally look at the transistors associated with the protection circuit! You could disconnect one end of the ntc and see if that makes a difference. Have you checked all the transistors with a meter?
    Olly.
  • 12-18-2011 10:17 AM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    The Beomaster starts and runs fine with the thermistor R160 removed.  Its value at room temperature is only 52 ohms which I think is low and would explain the behaviour I am seeing when it is in circuit.  Does anybody know the correct type or which other models similar ones were fitted to?  I have looked through my Beomaster graveyard but have found nothing similar yet...
    Richard
  • 12-18-2011 10:43 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Ah ok sorry mate well looking at the circuit I would go for a 1k ntc.
    Olly.
  • 12-18-2011 10:55 AM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    Well its colours are Grey, Yellow, Orange which I suppose would indicate 84k if it's the same as normal resistors.  Google only has a little information.  I will try my local shop tomorrow...
    Richard
  • 12-18-2011 12:12 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    You are far better going too low than too high! If emailing Martin (Dillon) doesn't come up with an answer and you want to find the highest resistance that will trigger the protection circuit (very important when choosing your NTC) then you could use a potenitometer in circuit turn from high to low and determine the cutoff resistance. Then choose a suitable ntc not from it's advertised value but it's 'resistance @ 80C' specs as an example.
    BTW how did you get 84k???
    Olly.
  • 12-18-2011 12:27 PM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    It was a typo,  I meant 94k ohm (should have proof read my post)
  • 12-18-2011 12:36 PM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    Now I look at in in another light it could be grey yellow orange which would be 84k ohm Confused
  • 12-18-2011 12:52 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Ah grey (8)  orange(3) yellow(1x104) would be 830k but silver is a multiplyer only (and tolerance) so that would possibly indicate 0.43R which again is worse than what you have now.
    84k seems way too high IMO.
    Olly.
  • 12-18-2011 1:24 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Martin has just told me it is in fact 330k 10%. I have to go eat my socks now :)
    Olly.
