dbitalia: I have heared when using the DVI input for hd material on bv7 it does not run the image thru the B&O image processor, its basically outputting directly from the source, is this the case??
You mentioned in this thread when you hooked up your PS3 to your fathers BV 7-40 the picture looked fantastic.So if you are pleased to that picture, it´s always going to look like that with HD DVI signals.
So if you just put in a DVI signal to the BV 7 it will take it through the scaling processor and the movie mode / automatic gain control / Comb filter will turn on.
The movie option are sett to Auto so if you always want to be certain that the Movie mode are on you can set the movie mode to ON (in the service menu).
(Movie mode contains: the vision clear, automatic brightness contrast colour, digital motion control, digital noise reduction and more and more.
Best Regards Fredrik L
