I have a 4600 with a pair of S-35's that was serviced before I bought it 2 years ago - and sounds lovely. However I want to play MP3's though it and the tape input at the back doesn't seem to work (the sound quality is v poor, and only works when none of the front panel source selection buttons are depressed).
Now that I know a little more about B&O, I'm faced with a choice. Do I pay someone to put a separate line into my 4600, and possibly upgrade to a pair of S-45.2 or would I be better going with something like a Beocentre 9300 or BeoMaster 4500 and some RedLine speakers in terms of sound quality? Am I likely to notice a huge difference in the quality?
Also, if I wanted to get a Beocentre 9300 or BeoMaster 4500 serviced (all the capacitors replaced), how much roughly would I be looking at?
Happy to hear your suggestions of other systems, but all I really want to do now is play MP3's (the only reason I like the 9300 or 9500 is that they look very very cool, but the 9300's are generally cheaper but I understand they sound the same).
