hi,
was wondering if someone could help, as i'm a bit confused re beolink cabling.
basically i have 3 b&o tv's all of which currently have just a standard tv aerial connection that runs from a splitter/booster box in the loft, plus the avant has a sky + box connected to it. what i'd like to achieve in the end is the ability to watch dvd's and
sky from the avant and obviously audio from the beosound, and then
standard terrestrial tv on each.
i realise i need to run a masterlink connection between the 3 but what i'm not sure is what i need to do with the aerial connection, ie. do i need to run 2 aerial feeds to the main tv (avant) or is it ok to leave it as is, with just the standard one in each tv - sorry if i'm not explaining it well, hopefully someone will understand !
thanks
steve
