Latest post 12-12-2011 6:45 PM by Tod Daniel. 8 replies.
Page 1 of 1 (9 items)
  • 12-12-2011 1:36 PM
    • bossbrad
    • Not Ranked
    • Joined on 07-02-2009
    • Colorado, USA
    • Posts 57
    • Gold Member
    BeoSound 8 vs BeoLab 4
    Looking to get some speakers for the bedroom and was wondering interms of sound quality which is better. They are both about the same price and I love the looks of both. I have an extra AirPort Express I would use to connect it with the rest of the house.
  • 12-12-2011 1:38 PM In reply to
    Re: BeoSound 8 vs BeoLab 4
    To my ears BeoSound 8 is much better than BeoLab 4.
    Go to your dealer Nd have a listen
  • 12-12-2011 1:41 PM In reply to
    Yes BeoSound 8.  Why not wait for the updated Airplay spec one in 2012? Or at least that's the rumour...
    Don't forget the awesome coloured grilles!
  • 12-12-2011 3:10 PM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Having had both. . .the BeoSound 8 is MUCH better. IMO
    The lab 4s have a very 'tinny' sound.  .
    I'm ready for something new that I actually want to buy!
  • 12-12-2011 3:45 PM In reply to
    • bossbrad
    • Not Ranked
    • Colorado, USA
    • Posts 57
    • Gold Member
    BeoSound 8 with AirPlay sounds like it would be worth the wait.
  • 12-12-2011 3:55 PM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    bossbrad:
    You already have an extra airport express and a $100 gift card.  Wait for what, Paul to buy one?
  • 12-12-2011 4:03 PM In reply to
    I much prefer the idea of Airplay than Airport Express - no extra boxes, cables and stuff to plug in and connect. But, each to their own I guess!
  • 12-12-2011 6:36 PM In reply to
    Paul Winn:
    A separate airport express allows you to position the bs8 in an area without very good wifi reception and locate the airport where you want.
    A separate airport express allows you to upgrade the airplay part if apple ever bring out AirPlay 2.
    A seperate airport express with the bs8 will be cheaper than the airplay version.
    Its still better to just dock the iPad or iPod anyway, for sound quality and battery life.
    I just don't get the need to have everything built in
  • 12-12-2011 6:45 PM In reply to
    I wont want to dock the iPad because id really like to use it whilst im listening to my iTunes or just leave it on a coffee table so its within easy reach that's why Airplay is appealing.  I'd of thought it would only add £100 to the rrp?
