Latest post 12-12-2011 1:41 PM by mbee. 1 replies.
Page 1 of 1 (2 items)
  • 12-12-2011 9:12 AM
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Beo6 Wifi with non-B&O equipment : hack or integrated?
    Now that the wifi is activated on the Beo6, I'm wondering if it can be easy to control non-B&O equipment that works with http commands on wifi (Sonos for instance, Freebox in France...), either by doing a fake-Beosound5 file, or directly supported by the Config Tool (I've not already installed the CT5.12)...
    Does anybody have any clue on that? I will try to find a way to control wifi stuff as soon as I go back to the CTool!
  • 12-12-2011 1:41 PM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Re: Beo6 Wifi with non-B&O equipment : hack or integrated?
    Ok, I've done a little tour of the Config Tool... Now I can reply to myself :
    The Config Tool has a new BeoSound5 xml file where we can see that there are a lot of non-IR functions...
    BUT the http (or other protocol) commands are hidden in the Beo6 firmware : the XML only tells to launchpre-defined functions embedded in the Beo6.
    That means that for now, I can't imagine any way of using the Beo6 to control non-B&O wifi-controlled products. Sad
    Other thing that I've discovered with the new firmware: the navigations through sub-pages are not circular again : if you go to the last page, a touch on the same arrow doesn't brings you to the first page.
